Hi!
#1
KFLOP actually has 8 hardware encoder inputs. But anyway MPG inputs are usually slow enough they can be handled in software so they can be connected to any two spare inputs. Does your MPG have differential outputs (A+ A- B+ B-) or just single ended (A B)?
#2
Yes that is basically correct. Actually index pulses can be connected to any input as they are handled in software. The index pulses are not required unless you wish to use them to improve your homing accuracy. In that case you might write the homing routine to move until a home switch is detected, then reverse until the first index pulse is detected.
#3
Yes there is an example called MPGSmooth.c
#4
When configuring and testing just download from KMotion until everything is working properly. Finally a C program will be created to configure KFLOP with the same setting so that downloading from KMotion is no longer required. See:
#5
Yes the Encoder resolution is set in KMotionCNC as Count Per Inch. Don't worry about that until later after your axis is working and tuned in KMotion.exe. The encoder mode is configured in KMotion.exe. Set the input type for the Axis as Encoder and set the InputChan0 to the encoder you wired it to.
There is an example configuration for Kanalog called KanalogInitialPID.mot. Load that into your axis to start with. Then change the InputChan0 and OutputChan for the encoder and DAC that you are using for the axis.
#6
Resolution x 4 Counts not Cycles
#7
Yes normally there are two C programs that you will need to create. One we refer to as your Init.c program that will configure and enable all your axis and also define your Coordinate system. The other would be a Home.c program to home all your system. You can assign two User Buttons in KMotionCNC to do these functions. But don't worry about this yet. Get everything in KMotion.exe working first.
Message: 3347 |
Date: 1/22/2012 |
Subject: Re: Getting Started with Mill Conversion |
Thanks for the quick reply, Tom!
Yes, the MPG has differential outputs. As it will have about 6 feet of
wire, I'd just as soon use the differential wiring.
The index pulses are also differential. I was planning on using them as
you suggest.
So does the "Download Channel' function have to be done after each
power-up, for each axis?
> Hi!
> #1
> #2
pulse is detected.
> #3
> #4
> http://www.dynomotion.com/Help/FlashHelp/Parameters/index.html
> #5
> Yes the Encoder resolution is set in KMotionCNC as Count Per Inch.Â
KanalogInitialPID.mot. Load that into your axis to start with.Â
you are using for the axis.Â
> #6
> Resolution x 4Â Counts not Cycles
> #7
and enable all your axis and also define your Coordinate system.Â
can assign two User Buttons in KMotionCNC to do these functions.Â
working first.
> HTH
> From: mrosenfield2 mrosenfield@...
> Sent: Sunday, January 22, 2012 6:57 PM
> Subject: [DynoMotion] Getting Started with Mill Conversion
> Hello, everyone!
> I have a Tree knee mill that I am converting to CNC. I was a two-axis
system with resolver feedback, and 96 VDC motors.
> I have replaced the resolvers with encoders, and replaced the old amps
with Advanced Motion Control servo amps. I will be adding servos to the
quill and knee.
> I have got the computer and Kflop/Kanalog talking on the bench, and am
now trying to set everything up before I move it to the shop.
> I have spent the last week reading the documentation and reading this
forum and the one on CNCZone, and I still need some help. Here are my
current questions:
> 1. An old thread talked about the KFlop supporting 4 encoders, but
changeable in firmware. I need 4 encoders plus MPG - is this currently
supported?
> 2. The manual says that J1 is used for encoders' A/B signal, and J2
for index signals. Is this still true? I assume I write some C code (or
find some for homing) to use the index pulses?
> 3. Is there any code written for handling a MPG?
> 4. The axis config has the option to download to KFlop or save as C.
Am I reading the instructions correctly that downloading is preferable
to putting the config info in C?
> 5. I'm planning on using KMotionCNC to actually run the mill. This is
where the encoder info is set up, but isn't this needed in Kmotion as
well?
> 6. The encoder counts specified to KMotionCNC are encoder resolution,
or resolution x 4?
> 7. The homing and setup is supposed to be put in a C program - when is
this called, and what calls it? Is it the buttons in KMotionCNC?
> Thanks!
Message: 3361 |
Date: 1/23/2012 |
ok so wire the mpg into a spare AB pair of differential inputs on Kanalog (JP1 or JP2). Also wire the index inputs to any spare differential inputs either A or B.
Yes while initially testing you will need to download to each channel to configure each axis after a power cycle.
The "Move" button on the Step Response Screen will also: Disable the axis, Download the Screen Parameters for the axis, enable the axis, perform a move forward and backwards of the specified size, upload data, and plot all the results. This is the most common way to test an axis.
But again after you have all your hardware working, tested, tuned you will then create a C program that will configure and enable all your Axes in one step which can then be triggered by a button in KMotionCNC or the RESET button in Mach3.
Message: 3368 |
Date: 1/23/2012 |
OK, got it!
Now I just need to mount the hardware and wire it to the machine, and
I'll see what happens when I drive the axes.
I'll be back...
Thanks again, Tom!
> ok so wire the mpg into a spare ABÂ Â pair of differential
axis.
> Sent: Sunday, January 22, 2012 8:24 PM
> Subject: [DynoMotion] Re: Getting Started with Mill Conversion
as
> you suggest.
> --- In DynoMotion@yahoogroups.com, Tom Kerekes tk@ wrote:
> > Hi!
> > Ã
> > #1
> > KFLOP actually has 8 hardware encoder inputs.Ã But anyway MPG
> can be connected to any two spare inputs.Ã Does your MPG have
> > Ã
> > #2
> > Yes that is basically correct.Ã Actually index pulses can be
> connected to any input as they are handled in software.Ã The
index
> homing accuracy.Ã In that case you might write the homing routine
to
index
> pulse is detected.
> > Ã
> > #3
> > Ã
> > #4
> everything is working properly.Ã Finally a C program will be
created
> KMotion is no longer required.Ã See:
> > Ã
> > Ã
> > #5
Inch.Ã
> tunedà in KMotion.exe.à à The encoder mode is
configured in
> KMotion.exe.Ã Set the input type for the Axis as Encoder and set
the
> > Ã
> KanalogInitialPID.mot.Ã Load that into your axis to start
with.Ã
> you are using for the axis.Ã
> > Ã
> > #6
> > Resolution x 4Ã Counts not Cycles
> > Ã
> > #7
> create.Ã One we refer to as your Init.c program that will
configure
> and enable all your axis and also define your Coordinate system.Ã
> The other would be a Home.c program to home all your system.Ã You
> can assign two User Buttons in KMotionCNC to do these functions.Ã
> But don't worry about this yet.Ã Get everything in KMotion.exe
> working first.
> > Ã
> > HTH
> > Ã
> > Ã
> > Hello, everyone!
two-axis
amps
the
> quill and knee.
am
this
> current questions:
> supported?
(or
is
> well?
resolution,
> or resolution x 4?
is
> > Thanks!
Message: 3372 |
Date: 1/23/2012 |
One more question: I gutted the Hoffman enclosure on the mill, and am
planning on installing the computer, KFlop/Kanalog, and new drives in
it.
Does the KFlop need any electrical shielding, or can I just bolt it down
in the enclosure? I didn't figure I needed a separate computer case
either, but now I'm wondering.
How have other people mounted their electronics?
--- In DynoMotion@yahoogroups.com, "mrosenfield2" <mrosenfield@...>
wrote:
> OK, got it!
> I'll be back...
> Thanks again, Tom!
> > Â
channel
> > Â
data,
> axis.
> > Â
you
> > Â
> > Â
of
> as
> > you suggest.
> > > Hi!
> > > Ã
> > > #1
they
> > > Ã
> > > #2
> index
routine
> to
> index
> > pulse is detected.
> > > Ã
> > > #3
> > > Ã
> > > #4
> created
> > > Ã
> > > Ã
> > > #5
> Inch.Ã
> configured in
set
> the
> > > Ã
> with.Ã
that
> > > Ã
> > > #6
> > > Ã
> > > #7
> configure
system.Ã
You
functions.Ã
> > working first.
> > > Ã
> > > HTH
> > > Ã
> > > Ã
> > > Hello, everyone!
> two-axis
> amps
> the
> > quill and knee.
and
> am
> this
my
> > current questions:
currently
> > supported?
J2
> (or
C.
preferable
> is
as
> > well?
> resolution,
> > or resolution x 4?
when
> is
> > > Thanks!
Message: 3373 |
Date: 1/23/2012 |
That should be fine in my opinion.
Message: 3374 |
Date: 1/23/2012 |
Here is a few pics of my mill/drill.
http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/list
I first had the KFLOP in a little project box before i made my "quick" Control Enclosure. The machine is a work in progress. :) Meaning...i like to make parts and tooling more than parts for machine. :) So i do a little at a time to machine, than take a breather and make other things. ;)
HTH,
Troy
> it.
> --- In DynoMotion@yahoogroups.com, "mrosenfield2" <mrosenfield@>
> wrote:
> > OK, got it!
> > I'll be back...
> > Thanks again, Tom!
> > > Â
> channel
> > > Â
> data,
> > axis.
> > > Â
> you
> > > Â
> > > Regards
> > > Â
> of
> > as
> > > you suggest.
> > > > Hi!
> > > > Ã
> > > > #1
> they
> > > > Ã
> > > > #2
> > index
> routine
> > to
> > index
> > > pulse is detected.
> > > > Ã
> > > > #3
> > > > Ã
> > > > #4
> > created
> > > > Ã
> > > > Ã
> > > > #5
> > Inch.Ã
> > configured in
> set
> > the
> > > > Ã
> > with.Ã
> that
> > > > Ã
> > > > #6
> > > > Ã
> > > > #7
> > configure
> system.Ã
> You
> functions.Ã
> > > working first.
> > > > Ã
> > > > HTH
> > > > TK
> > > > Ã
> > > > Ã
> > > > Hello, everyone!
> > two-axis
> > amps
> > the
> > > quill and knee.
> and
> > am
> > this
> my
> > > current questions:
> currently
> > > supported?
> J2
> > (or
> C.
> preferable
> > is
> as
> > > well?
> > resolution,
> > > or resolution x 4?
> when
> > is
> > > > Thanks!
Message: 3375 |
Date: 1/23/2012 |
FWIW - I have my KFlop mounted in the same enclosure with ALL the other electronics - breakout boards, power supplies servo drives, VFD, relays, PC, etc. Works fine.
Ray L.
> it.
> wrote:
> > OK, got it!
> > I'll be back...
> > Thanks again, Tom!
> > > Â
> channel
> > > Â
> data,
> > axis.
> > > Â
> you
> > > Â
> > > Regards
> > > Â
> of
> > as
> > > you suggest.
> > > > Hi!
> > > > Ã
> > > > #1
> they
> > > > Ã
> > > > #2
> > index
> routine
> > to
> > index
> > > pulse is detected.
> > > > Ã
> > > > #3
> > > > Ã
> > > > #4
> > created
> > > > Ã
> > > > Ã
> > > > #5
> > Inch.Ã
> > configured in
> set
> > the
> > > > Ã
> > with.Ã
> that
> > > > Ã
> > > > #6
> > > > Ã
> > > > #7
> > configure
> system.Ã
> You
> functions.Ã
> > > working first.
> > > > Ã
> > > > HTH
> > > > TK
> > > > Ã
> > > > Ã
> > > > Hello, everyone!
> > two-axis
> > amps
> > the
> > > quill and knee.
> and
> > am
> > this
> my
> > > current questions:
> currently
> > > supported?
> J2
> > (or
> C.
> preferable
> > is
> as
> > > well?
> > resolution,
> > > or resolution x 4?
> when
> > is
> > > > Thanks!
